i have a few concerts to put to dvd and would like to make origanal menu`s for them instead of the generic ones you get with some software.what is the best program to do this and how newbie freindly is it thanks
Don't know whether its the best or not but I use TMPEGEnc DVD Author to make custom menu's within their framework.
Easy to idiot proof to use but does take a lot of time to render the menu. Especially when you move things around.I have had one project take over 3 hrs.Only bonus to this is I can run more than one at a time. -
The 4 hrs to render is because I'm using 3 min motion menu's.With and average 3 pages and 35 chapters that's a lot of trans-coding?..
Dvd lab doesn't even do this task.It hands it of to guess who?
TMPEGEnc.Which is no speedy encoder itself.
If you want to create great pro looking menu's in one evening TMPEGEnc DVD Author is vastly superior.However,if you want complete control and are willing to spend the time learning or are familiar with video editing software,then DVD-lab is for you. -
If your good with Photoshop, you can make just about any menu you want with Encore DVD. As far as being user friendly, you might have to buy a book, & spend an afternoon learning it.
Help with making menu's!!!!
By BananaKing in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2011, 08:55 -
DVD Demuxer tool making 0kb .VOB files
By Madvillain in forum DVD RippingReplies: 5Last Post: 6th Jul 2009, 05:11 -
Deinterlacing menu conflicts within DVdate tool
By Pierre1 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2009, 09:43 -
particular Menu-making feature
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 15th Feb 2008, 16:38 -
is there a freeware tool for making an image of my c drive?
By surfmonkee in forum ComputerReplies: 17Last Post: 10th Nov 2007, 21:01
